Hi all. Thanks again for your contributions, advice and support. This has been quite an undertaking and I’m making progress, I hope to have the engine back in the bike this week!
The bottom end is now assembled, I just need to give the cylinder head mating surfaces a once over, do the valve clearances and then put it all together with the new head gasket.
I plan on just putting the 10w40 oil I would normally use in, as well as flushing the coolant system out with tap water multiple times before filling it with coolant/distilled water.
Any tips on first start up would be most appreciated. My plan currently is to crank it multiple times without the plugs in, to build oil pressure. Then install the plugs and start it up, just idle it until it reaches operating temp, switch it off, and do that again once it’s fully cooled. Then once I know it’s runnng ok and I’ve checked everything over, I’ll do some short road testing. Any other tips such as what rpm to keep it in/ idle speed/ to idle or not to idle would be helpful.
Also, how soon after running should I be doing an oil/filter change?
This has been a huge undertaking, I’ve tried my absolute best not to miss anything, keep everything clean, plenty of oil and assembly lube on moving parts, assemble things the correct way, although naturally I’m feel pretty anxious about trying to get it running once again…
