Clutch cable maintenance?
@grcamna7 -​
If you've not removed/ replaced the airbox before, make sure you've got a set of *long* allen key wrenches, because the bolts that hold it to the throttle bodies are buried deep underneath it. Loosen them off, but DO NOT remove them!
Also apply some Red Rubber Grease to the rubbers at the bottom of the airbox when you come to put it back on, because that will help it go on so much more easily.
Will Do 🙂
Do you recall 3 or 4mm ?
