razormac214
Looking to do a few performance mods to my '06 FZ6 this spring, and just had some questions before I moved forward.
- I already have the Scopion Oval Exhaust installed but I am looking to get the K&N replacement air filter as well. Will the bike run okay without dyno-tuning or a power commander? For example will it be running too rich for the stock setup causing all sorts of backfiring?
- If I do get a Power Commander I was looking at the Dynojet Power Commander III USB EX. I do not know a lot about this so forgive me if these are not the most intelligent questions. Will I need a customized map to make my combination of parts run best together or does the Power Commander come loaded with a mapping that will work just fine?
- If a customized map is best then would anyone know who or where I could get one from?
- Is the installation of the PC relatively simple? Does it just sit under the seat once you get it installed?
- Any estimates of improvements I might see with all of this? I am think 4-7 hp, would that be way off base?
Any information or helpful links that you can provide would be awesome. Thanks in advance.
