odachi13
So, to start on Monday just setting off from work and shifting up through 2nd then into 3rd the clutch cable snapped right a the lever - which was a learning experience to try and deal with and an horriffic sound from stalling the bike in that gear as I came to a safe stop.
Had a new one delivered to work, where I wheeled it back to. It seems to be just a bit too long despite matching the old one when I took it out. With everything on it's max, I can't seem to get it tight enough - the lever operates the clutch but doesn't pull back.
A mate suggested that the spring down at the clutch case seems weak and has perhaps deteriorated, could this be a cause or is there just something else stupidly obvious i'm missing?
