I have noticed that the text formatting seems to get displayed when you quote peoples posts. I'm not sure if it is the browsers fault or the site. ![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I have noticed that the text formatting seems to get displayed when you quote peoples posts. I'm not sure if it is the browsers fault or the site.![]()
\\\"mmm, strange\\\"
Let's see..... It's likely a recent update from Dennis has changed the coding a bit. What you see is a typical leading \ in front of symbols which allows the site to display the characters without treating them as codes that would otherwise change what is quoted. Does that make any sense?
It's bascially telling the site to ignore the character as code and treat it as text.
The root cause is probably the ability to display the ampersand sign without treating it as code. For several languages branching from HTML the & is a special character that envokes certain logic. So the code expects something to follw the & sign:
So if the code just sees & then it gets confused because there is suppossed to be something following it. A way around it is to proceed the & with code that allows it to be treated as text another is to replace the ampersand with the & ASCII code so it displays as &.
I noticed it too, but I just thought it was extra emphasis on the quotation marks. Kinda like italics.
\"Try this one Dennis!\" quote me!
[COLOR=\\"Blue\\"][SIZE=\\"4\\"]example text[/SIZE][/COLOR]
this thread is above my head, but i hope it gets all fixed up...
Quoted...............:thumbup:
