This look's easy too build and very strong...
Nice! I think I already have a lot of what this is constructed of. Time to engineer! Thanks!
Rob, this is a cool thread and it brought out some really nice ideas! Thank all! Awesome fab work going on here!
The attached pdf is a dimensioned drawing of the parts. There may be misspellings I r not a spelar..
This is only my ideas on how I would build it if I were to build it. I have not as of yet and someone else came up with the idea. Hope this can help someone.
I built this one exactly to the directions and it does not work.
Back to the drawing board. A broken handle, no leverage left me with cutting my tire off. but i did get the tire changed out, but with no help from this build.
The main issue i think with this on is that it was designed to be made with a single 2x4 board and it was far too small. I think the overall design was good and i might re-build it but it will be twice the size (Except the drop arm which will only be about 6 inches longer) I had no leverage on the bead and it was too close to the wall for me to set the drop arm correctly.
Just an FYI in case anyone was thinking of building it.
Thanks for the update. I pretty much drew that from other peoples designs. I'll try to remember to update it when I return to work Monday. Stronger arm, Longer arm. Any suggestions on length?
It says "small motorcycle" has anyone used that thing on a motorcycle on a 17" rim? they limit it to small motorcycle but then give no maximum size...
