sxty8goats
I ordered some 3M reflective tape from amazon. It is black that reflects white. The tape was surprisingly flexible at 1/4 inch wide. A 100 ft x 1/4" roll cost around $15. I had hoped to be able to put a stripe or two around the helmet in fairly non-conspicuous (when not reflecting) pattern so as not to ruin the graphics. I experimented with the flexibility and was pleasantly surprised..
Back of the helmet. The strip across the back is the only place that the tape is noticeable if there is no reflection. The rest of the tape blends into the patterns nicely.
Detail shot to show how nicely the tape works around curves. The curve in the front is pretty much the limit of the tape. I'm guessing @ a 2" radius. The sharp bits were cut in at an angle to fit. Two pieces of tape meet at the corner/sharp bit.
