stevesnj
What is the best lubricant to use to lube the ignition key cylinder? it's hard to insert, turn and remove key. Key isn't bent
Graphite.. buy it at your local hardware store.
Do I get the spray version or dry?
My 07 is exactly the same way. I actually couldn't get the key to turn in the ignition at one point. I retreived the spare key at it turned fine, but the original key still has a very hard time finding the right tumblers. They key goes about half way in then meets some resistance and need a jiggle to get it all the way in. It's quite annoying to say the least.
