ahmet1257
Hello, I bought a 2004 FZ6 with approximately 130,000 km on it. After 300 km, the engine stalled after warming up. I waited 10 minutes for it to cool down and it started again. When it warmed up again, it stalled again. I waited another 10 minutes for it to cool down and it started again. On the way home, it stalled again. It wouldn't start. I waited two days, then tried pushing it to start and it worked. When I got home, it wouldn't start with the starter button either. The fuel pump engages, the engine spins and I smell fuel, but it doesn't start. (I also tried starter spray, it didn't work.))
I checked the ECU, no problem.
I checked the wiring and ran a continuity test, no problem.
I checked the sensors, no problem.
All measurements seem to match the manual. The starter motor spins very well. Recently, while trying to start the car again, I accidentally touched a wire (right handlebar control wiring harness) and there was a noise from the main relay on the left rear. The engine started, it was night, I immediately stopped it and tried again many times. I checked all the wiring but couldn't get it to work. No ignition. Coil and spark plug measurements are correct, no problems apparent. Unfortunately, I can't order parts from abroad to my country and they are very expensive here. I need to diagnose the fault directly through trial and error. Unfortunately, I can't do that.
By the way, I cleared the error codes on the DAIG and when I started it again, it didn't give any error codes.
My English isn't very good, please excuse that.
