- Joined
- Feb 7, 2009
- Messages
- 12,555
- Reaction score
- 1,207
- Points
- 113
- Location
- Cape Coral, Florida, USA
While going over the bike the am, I noticed when downshifting fully, the inside of the shifter lever itself was just touching the kickstand bolt.
The bike shifted fine, I do have the adjustment set low (personal preferance).
Looking closer, I ended up bending the shifter itself out maybe 1/8" (the bike had been down by the PO). (the shifter was was removed and put in a vise, DO NOT ATTEMPT ON THE BIKE).
I also noticed, see below pictures, that the entire shifter arm does have a physical (non-adjustable) stop where it passes thru the mount. The second picture is AFTER I pulled the shifter out about 1/8".
Noteictures took were with the shifter in the full DOWN POSITION. You can see the actual head of the kickstand bolt is shiny where the the shifter was just touching it.
Everythings re-adjusted and straightened out, still, no issues...
*Point being, IF your having DOWNSHIFTING PROBLEMS, check to make sure you have physical clearance between the shifter arm itself and the aluminum plate it bolts to... If it hits, your physically not able to fully downshift the mechanism..
BTW, for adjustment purposes, the lower end of the rod is REVERSE THREADED. The locking nut is 10mm, the Heim joint ends are 11mm with the lower fitting having 4 flats to keep all the heim joints lined up..
