ChevyFazer
Redneck MacGyver
I thought it looked kind of evil this morning lol
By the way any of y'all have a clue why it won't go above 3rd gear?
Besides re-installing the oil pan, did you do anything else to the bike?
Also, when you try to shift upwards, (3rd and up gears) does the shifter move as usual or lock up? Do the lower gears (that do work) engaug and stay (especially the shifter) in gear?
Sounds like something exterior may be binding up with your shifter linkage.
The shifter drum (under where the small, short shifter shaft exits) has a roller mounted on a plate that's spring loaded and holds the shifter drum in a particular gear).
If you look up the post, (its long now) (AdamFZ), he's just torn down his transmission and has pictures of the above and then some!!!
Here it is: http://www.600riders.com/forum/garage-mechanical-help/48071-broken-my-gears.html
The transmission shifter pic's are much later in the thread, start at about page 4...
