Weird handlebars from ebay
SANGER_A2
Southampton
Looks like they will be buzzier by far than the stock bars. You may be getting less wrist paint - but your hands will probably go numb from the vibes. Also, if you buy I would locktite the crap out of those nuts and check them often! There is a reason the stock bar-ends are so heavy, if you tap the bars you can use the stock bar-ends and that will help. You can also fill the bars with something to make them heavier (I used sand). Also, get triple or dual-density pro-grip gel grips to absorb some of the vibes. You can even add grip puppies if you can ride with them (I tried them and hates how wide they were - but they were amazing at absorbing vibrations). You can see how I reduced my vibes in my site link below.
