- Joined
- May 6, 2014
- Messages
- 2,532
- Reaction score
- 2,841
- Points
- 113
- Location
- Amongst the Twisty Roads
Winter time = Project time.
On the bike operating table is a bike I bought 3 years ago, a 1976 CB550F Super Sport. I've been waiting until I retired to do a full restoration on this bike...and I retired on August 1st. Time to get crackin'.
I bought this bike from an 18-year-old after he had put a few thousand miles on it. I know...sounds like a red flag...probably is. The bike wasn't running right for him so he decided to rebuild the carbs...took them a part...and got in over his head. I met both the young man and his father at his father's garage. Dad is in the heavy equipment business. He wasn't happy about his kid getting a motorcycle...and let him get into the project to see how it went. He assured me that the bike is a runner, but it was running too rich (we will come back to that). According to the title, the kid bought the bike in August 2022 with 2,720 miles, and I got it 2 months later with 5,857. Did he really put 3,137 miles on it in two months? Maybe he rode it a while before it was titled.
Overall the bike is in fair condition. It looks like it was largely garage kept. There is some corrosion on the fork caps and shock bolts. The tank is in good condition as are the side panels (the left is a little warped on the top edge due to what appears to be a fried circuit in the fuse box). It looks like the owner at that time moved the fried circuit to the spare to the right. I'll investigate.
I have been giving the bike some thought for a few weeks, deciding how to tackle a non-running project that I want to do a full restoration. My thought process is to first get it running to see what else needs attention. To that end I got the bike up on my stand and gave it a compression test. Since the bike has sat dormant for years, I figured a wet test would be needed. The factory spec for compression is 170 psi, with an acceptable range of 150-170 with no more than 10 psi varriation. The battery is holding a steady 8VDC...so the kick starter (remember those) came in handy.
Round one: With 10 kicks cylinders 1-3 show between 50 and 54psi. Cylinder #4 shows 53psi..I give it an extra kick and the reading jumps to 75psi. Hmm...I wonder of 1-3 will show a similar improvement with a few additional kicks?
Round two: Cylinders 1-3 show between 75 and 78psi. Cylinder #4 now shows 110psi. I like where this is going.
Round three: Cylinders 1-3 show between 120 and 125psi. Cylinder #4 now shows 148psi. Let's do this one more time....
Round four: Cylinders 1-4 show between 152 and 155psi. No need for a wet test. I'm in range with a stone-cold engine.
About the spark plugs I removed for the compression test; I can see why father and son suspected it was running rich...
This bike has an open exhaust...no muffler at all (check the top photo)...so yeah with stock jetting those plugs don't surprise me. The reason it has no muffler - someone decided to modify the exhaust...but they cut the pipes BEFORE the collector. They realized their mistake and tried to fix the problem with muffler wrap. So yeah, that's a cluster *uck. One of the unique things about the 550F is the header pipes...they wrap around beautifully into a 4-into-1 collector. An aftermarket exhaust isn't an option for this project, but luckily I've had three years to check eBay and sometime ago scored a 550F in very good condition for $25.
So the other thing I have to do to get this bike started is to rebuild the carbs. When I got the bike I received an assembled carb bank, and a bag of removed parts. The bag of parts looks complete, but I've ordered a carb kit because I have no idea the condition of the brass and all of the rubber is dry (o-rings and boots/isolators). I now have the carbs completely disassembled and ready to go through my Vapor Blaster and Ultrasonic cleaner.
Stock jetting is Keihin 100 main & 45 pilot jets. The jets that were last installed appear to be from a Keyster rebuild kit...likely what I've ordered. Keyster kits are good...but I may buy Keihin brass and not use the jets in the kits.
Hopefully I have the bike running in a few weeks. I have a new battery on order, and by the time I get the carb rebuild parts I should have everything cleaned and stagged for reassembly. I'm hoping the engine runs well...but if not I'll fix what is needed. I'd rather not rebuild the engine... I do plan on painting the engine...so if I have to rebuild the engine it does make painting a lot easier. We'll see.
