miketherider
Picked up a 2005 FZ6 from the original owner. Has 4800 original miles. Would not start so picked it up on the cheap.
Original owner let it sit for almost 3 years. Has a brand new battery; checked all connections and main fuses.
First problem was a broken connector at the fuel pump; the green/brown wire on the white connector had broken. Fixed that, which erased the 43 error code. Also had a blown fuse so changed that. Tried to start to no success.
Went ahead and changed plugs, cleaned the intakes and injectors. Air filter was clean.
Still no life. So, I pulled main line coming from the fuel pump. When I hit the button, no fuel comes out.
I dumped some sea foam in the tank when I first brought it home in the hope it would clear out some of the bad fuel in it.
When I first turn the key on, I can hear the pump, but only with my ear close to the tank; it sounds like a bubbling inside. But, still no fuel coming from the pump after I turn it on.
Should I look into a new fuel pump or look to see if the filter screen is clogged? What is involved with getting at the screen? Going to drain it tonight to tear at it tomorrow.
