- Joined
- Feb 7, 2009
- Messages
- 12,550
- Reaction score
- 1,197
- Points
- 113
- Location
- Cape Coral, Florida, USA
Yes, the piston will stick out as the pads wear and will be visable. It's NOT going to retract fully or you'd need a lever that moves 6".
The best way to see how much drag the rear brake has is to take the chain off the rear sprocket, (secure it to the swingarm, out of the way), then just spin it(after retightening everything back to normal, pumping up the brake).
A little to some drag is normal, again, if it stops in a half a turn, somethings wrong/binding/pressurizing, etc.
With the chain on, its really hard to tell how much the brakes are/are not dragging.
Also, if you go for a ride (approx 40-50 MPH) and stop with the FRONT BRAKES ONLY, then quickly feel the rear rotor. It should be cold or ambient temp. If its hot, the brakes are dragging excessively. *Same procedure can be used for checking the front rotors
Making sure the brake slider bolts are clean with fresh brake grease is really important as they allow the entire caliper to center itself (with one piston and two pads, it slides to center itself for even pad wear). Hopefully you used Brake specific grease (won't fling off, super high heat resistance, etc)
BTW, did you find anything unusual inside, sliders stuck, anything?
