Carlos840
So, i wanted to change my fork springs and oil.
After a bit of research i have decided to first experiment with different oil weights and trying to shim the stock springs to get proper sag in the front.
It's a lot cheaper, and since i am only 176 lbs i think that i might get away with it as my current sag is not to far from what it should be.
There is one bit of information i cannot find a definitive answer for.
Should i shim on top of the spacer or under the spacer (add a spacer on top of the stock one)?
Thanks
Thanks
