weehe
I clearly can't catch a break with my rear wheel. All of this started after taking my wheel off to have the tire replaced. I rode for ~1000 miles problem free before removing the wheel. In a previous thread I figured out the odd crunching sound I heard, after putting the wheel back on, was from a bad roller bearing. I recently replaced BOTH roller bearings even though the right side (disk side) seemed fine. I lubed everything back up and put it back together. I then rode for ~200 miles problem free. Yesterday the clunking/crunching started again, worse than before. I took the wheel off and found my new, right side roller bearing is toast. The inner race can move in and out by about half a centimeter and the red seal is partly peeled back.
I am at a lose for what I could have done wrong. The bearings went in fine and I torqued the axle nut to 87 ft/lb like the manual says. I have some concerns about the spacer in the wheel. Is it the only spacer? (the manual only shows the one long one) I ask because it seems like it is lose and moving around. It can slide past the needle bearing and bounce off both roller bearings. I think this is how the roller bearing was damaged, the spacer was constantly hitting it.
I took a bunch of pictures in a hope someone will see something obviously wrong. Let me know if you have any ideas.
![](/proxy.php?image=http%3A%2F%2Fi903.photobucket.com%2Falbums%2Fac240%2Fweehe%2F20150430_1824391.jpg&hash=db883418a846c50276419011f11485f4)
Left side, looking into wheel and needle bearing. Should the spacer be that loose?
![](/proxy.php?image=http%3A%2F%2Fi903.photobucket.com%2Falbums%2Fac240%2Fweehe%2F20150430_1825341.jpg&hash=0a0075fcacd940e5d8f949c033684c37)
Inside of sprocket roller bearing
![](/proxy.php?image=http%3A%2F%2Fi903.photobucket.com%2Falbums%2Fac240%2Fweehe%2F20150430_1825581.jpg&hash=1e83ec914e4e23944223a1fc4c247863)
Outside of sprocket roller bearing, looks a little damaged and has some binding when spun on my fingers but has no play
![](/proxy.php?image=http%3A%2F%2Fi903.photobucket.com%2Falbums%2Fac240%2Fweehe%2F20150430_1826421.jpg&hash=8402b5ca199a92cfbe798d98b8e50677)
Right side roller bearing
![](/proxy.php?image=http%3A%2F%2Fi903.photobucket.com%2Falbums%2Fac240%2Fweehe%2F20150430_1827431.jpg&hash=2ec62415e6412550d55aba82dadbecd8)
right side roller bearing, shows damage a little better
![](/proxy.php?image=http%3A%2F%2Fi903.photobucket.com%2Falbums%2Fac240%2Fweehe%2F20150430_1831551.jpg&hash=4947854720de9e9a963e2c55df6b3d39)
Right side spacer, is flush or inside hub. Can move since there is play in the bearing
![](/proxy.php?image=http%3A%2F%2Fi903.photobucket.com%2Falbums%2Fac240%2Fweehe%2F20150430_1832051.jpg&hash=cdd8499c8223d8ae151e216bc45fed07)
Left side spacer, looks almost too far out but does not move/have play
