erburtt
Okay, so I'm a bit confused here... I replaced my stock chain last season when it had around 40,000 km on it, I was seeing red dust periodically on surrounding parts and under the sprocket cover. I did consider the sprocket spline shaft itself, but ruled it out.
So I installed a new x-ring chain, cant remember the manufacturer, but a decent enough one. I might have had it a tad bit tight for the first 200 km or so, but since then its been adjusted correctly, cleaned and lubed like every 2000 km or so depending on when I got the chance.
I put it away freshly cleaned, lubed and adjusted for the winter. This season I got probably 1000 km in before it seemed quite loose and I was seeing the red dust again, I adjusted, cleaned, and lubed once again and all seemed fine. I recently went on a bit of a tour in the states, did 1800 km in around 3 days, haven't ridden in rain since I got the bike out of storage and it was beautiful weather for the whole trip. Well now there's red dust everywhere, the chain slack seems a bit loose again, I can safely say the red dust is for sure coming from the chain... I just don't know what I've done wrong, before I knew anything about maintenance I ran my GS500F for 10,000 km without touching the chain in rain, dirt, everything you can think of... Never had an issue. Now that I'm religiously taking care of my chain its seemingly failing faster than ever. Do I need to drop the $250+ on a D.I.D chain? are they really that much better in quality?
