- Joined
- Feb 7, 2009
- Messages
- 12,555
- Reaction score
- 1,207
- Points
- 113
- Location
- Cape Coral, Florida, USA
I'm curious about this too as I'm about to remove the wheels. How does the extension fit into the spark plug hole? Do I remove the plastic that holds spark plugs?
Yes, the inside material needs to be removed so you can get the extension in.
And you should remove the calipers BEFORE or your scratch the snot out of your wheel..
Or, if you have a welder, make your own tool (3/4" bolt, washer and nut welded together) :
