b.polley11
Ive got a 2009 fz6. Had to get the tank repainted and while it was off I repainted the frame because the previous owner painted red stripes on it. Went to put everything back together and it wont stay running unless I use starting fluid. It will barely idle for a couple seconds and then turn back off. Started replacing fuel pump and a few others.....nothing. Pulled the injectos and cleaned them, put fresh gas, changed spark plugs, etc. Then went to make sure injectors were getting power when I was cranking it over with a test light and BAM it started. Pulled the test light off the wire and it died. So somehow I have a bad ground and cant seem to find out where or which one, any ideas where to start?
