Athosch97
what is zady5 mod? I have the same issue and waiting for someone to solve it ;pNot yet. Still waiting piggy's feedback.
Want to try zady5 mod. I wll report results.
Not a whole lot? Reading posts #105 and #110 seems worthy to give it a try. If i can get rid of, let's say, 50% of the snatchiness for 2 bucks i'll be happy enough.read this thread, but basically adding some diodes and resistors across tps sensor, moving tps signal up in rpm, so fuel cut would happen later (I think)? As people pointed it helps (kinda) but really not a whole lot. And from my experience with engines I think it can make low rpm driving worse. Also as Ivan noted in that thread it does not remove the core problem just eases simptoms.Zady5 Throttle Snatch Method
hello everyone I'm Italian, I have a yamaha fz1 (pictured avatar). I would like to attend your site to learn more about my bike and to learn English. thanks to all I know the way to eliminate the annoying fuel-cut all yamaha have. if you're interested I'll post how to do, and 'simple and very...www.998cc.org
I hope you're right. I'll wait for an updateNot a whole lot? Reading posts #105 and #110 seems worthy to give it a try. If i can get rid of, let's say, 50% of the snatchiness for 2 bucks i'll be happy enough.
I have it prepared, just need to find a day to install it and try.
Hey I would really appreciate if you record it! If it's easy for you I would love to see step by step how to do it and give it a try! Thanks!Not a whole lot? Reading posts #105 and #110 seems worthy to give it a try. If i can get rid of, let's say, 50% of the snatchiness for 2 bucks i'll be happy enough.
Love to hear that! I'll text again once I finish work! This got me hyped up!!Tried after 140 km of pure twisties. The mod works well. Have to say it's not the final solution but for me it's good enough. No more throttle snatch form 3rd gear up and a better throttle response in 2nd. It's not smooth as butter but its a much more tamed snatch. For 3 bucks it costs it's a no brainer mod.
You are a legend! Thank you!Enjoy.
Where did you get the connectors? I can get the diodes from an electronic component supply store here in Canada but when I went to an automobile supply store to get the connectors they just shook their heads.Here is how to do the Zady5 mod adapted to the fz6 wiring. First locate the IMAP sensor. Under the tank and right side of the bike:
You will need x4 1N4007 diodes. welded in serial conection and a pair of denso type conectors. model 174359 and 174357. Should like something like these:
View attachment 75711 View attachment 75712
Then follow the diagram and assemble. It's in spanish but you can translate it
You should end with something like this:
Disconect the original harness and put that shit in between.
Enjoy.
I bought mine online on aliexpress (chinese store)Where did you get the connectors? I can get the diodes from an electronic component supply store here in Canada but when I went to an automobile supply store to get the connectors they just shook their heads.
Hi, I've just done the same. It takes a month or so to reach Canada but the price is right. Thanks for the tip!I bought mine online on aliexpress (chinese store)
