- Joined
- May 6, 2014
- Messages
- 2,518
- Reaction score
- 2,809
- Points
- 113
- Location
- Amongst the Twisty Roads
Send photos of the inside of the cylinders. If there isn’t any scoring and the cross hatching is in good shape, you should be able to reuse the rings.
With the head off, now would be a good (and easy) time to check the valve clearances.
Get a gasket scraping tool to remove the old head gasket, it makes life easier and ensures that you don’t gouge the head with a utility knife (not to mention much safer for your fingers).
Clean the carbon off the heads, valves and pistons with brake cleaner.
As you remove pistons, use a Sharpie marker to note which cylinder they were removed from.
Get some assembly lube for reassembly - you don’t want to put the engine together dry or have a dry start. Lube all rotating surfaces (bearings, cam journals, buckets…if it turns or rubs it gets lube).
I haven’t read the FSM for reassembly in a while…but if it recommends using Yamabond sealant…don’t substitute with something else…use the sealants called out in the FSM. With that said…I’ll probably read that section tonight just to have the procedure in my head for future questions.
