I disconnected the battery for 5 hours. Then i entered at d61 and there was a 12 error, which i deleted. Exited diagnostics, cranked, did not start. Switched off, on, retried, got the mechanical lock (discussed earlier) in the first one or two seconds of cranking, immediately released the starter button, retried and got the lock again and on the third attempt it started like a charm. So here is the mechanical lock in the discussion again. Could it be a) something hitting on the ckp sensor ? b) could it be the starter not properly engaging, not turning the crankshaft, thus no signal generated by the ckp sensor and error 12 is finally correct? The mechanic had the starter engaging mechanism checked and found nothing abnormal visually. But the symptom exists, so something is hitting somewhere during cranking.
here is the video i had the mechanic lock captured in the past.
No error codes. Today it happened again and got it on video. The "mechanical block" also happened, the one I was thinking it was from the starter clutch. But combined with the fuel pressure suspicion, could it be a hydraulic lock by a leaking injector ? You will see in the video when the lock happens (if it is such) the voltage collapses and I immediately release the starting button and try again.
Today it appeard almost immediately, the starter was cold, it appeared twice and then it started ok.
Combining everything together someone could say that the starter sometimes engages but locks on something solid and stops (thus the voltage massive drop), sometimes it does not engage at all so the crankshaft does not turn and no signal is generated towards the ecu and sometimes it engages normaly, nothing gets mechanically blocked and starts ok. Also when the mechanical lock happens, it always starts after some attempts. When it doest happen (usually it does not) the bike either starts fine or starts after many attempts (where one of the following was tried: ignition off-on [ priming or ecu reset ? ], d09 and d30 [priming or ecu reset too])
In the meanwhile, I am not sure if it will help but I am planning to monitor the ckp signal with a portable oscilloscope when the DJ7026 connectors arrive ( I ll make a Y cable to steal the signal without back probing or hurting the existing harness).
