Nubzshop
Just started making these and thought you guys might like the look!
The fairing plugs eliminate the stock signals and fill the hole left in the fairing for a smooth look. The kit comes with all the accessories and instructions to remove your stock signals and mount the included signal hardware in the OEM podlight mounts in the upper corners of the headlights.
Turn signals come with resistors installed to keep the factory flash rate. The Kit has been made as plug and play as possible, all mounting hardware and wiring accessories are included. Should not take longer than 30min to install!
Available NOW at Nubzshop.com!!
Thank You!
Thank You!
