Bar ends
RustyBasterd
Raleigh NC
Ok so I ordered the rideitmoto levers and they came with free grips. I tried to take off the bar ends with and allan wrench I ended up striping one of them. But I noticed that there is a smaller wrench size and a larger one on each end is there and trick to this?
Use the big one, and it just unscrews in one solid piece. I don't know why that smaller looking hole is there.
Use the big hex key (9mm ?) and it should come off pretty easily. If you can't budge it use a rubber mallet to help free it. I hesitate to use a 'cheater bar' as you can break the hex key and cause damage.
Yeah, it is secured with a thread locker (and should be re-secured as such), but a hex key - 8mm from memory, and a short jerk should remove it. I know, because at 5'7", I've been called a short jerk, and I had no problems.
