oldjeep
Active Member
Have a couple of disconnected wires that I am trying to find a home for. This one (green connector) is a weird one. 3 wires coming out from the horizontal blade and 2 (red and black) are just bare ends. Any thoughts? Not even sure that it is stock, but I have not tried unwrapping the harness to see where the other 2 wires wind up. Note - this bike did not come with a stock airbox, so if there is a sensor on that then it is likely for that.
2 here. Pretty sure that the one with the wire tap on it is the remains of the kickstand switch wiring since on the other side of the bike the kickstand switch is dangling and its connectors are missing. The one I am curious about is the black wire with the ring terminal. Would assume it is a ground, but no idea where it should be hooked up. Not long enough to reach the battery.
