4 The F4llen
I just purchased a 06 Yamaha FZ6, 6800 miles, and PERFECT condition. Not a scratch on the thing. I had 2 other people besides my self check every nook and cranny for anything suggesting it may have been dropped. Nothing.
Anyways, went out to look at it, drove it around for a while and every thing seemed absolutely perfect. Shifted great, throttle felt perfect, everything was 110%.
I got it home and spent about 2 hours driving it around the mall. Working on clutch control, braking, starting, cornering and getting the feel for my bike in general. After a while I came to a stop sign, stopped the bike and all of a sudden it died. WTF? I looked at the heat gage and it was on the highest level, though I never got any warnings or anything. I had suspected that it died because it got too hot. (I had been running it for about 2 hours or so basically only in 1st and second gear. Probably wasn't getting near enough air to cool it down.) Anyways I took the bike home and charged it for about 2 hours when I woke up and it fired up no problems.
I was curious as to why it had died because I was sure that even at low speed, low rpm, and low gear the stator should be charging the battery. Took the gas tank up and tested the battery. It was pushing a steady 12.8 volts when the bike was off. When the bike was on it was pushing about 12.3 at idle and fluctuated a little. Typical range was about .3 of a volt up or down but seemed relatively steady.
I also tested the cables to the stator. All 3 phases read 0.9 ohms and were consistent.
In my mind the stator was working and the battery was working. I put the voltmeter on the battery terminals and rev'd between 3k and 7k rpm and the volts went up depending on how high the rpm's were. Though, at idle the bike lost about .5 rpm from when the bike was off.
In my mind the battery is obviously working, the stator is obviously charging but only at any rpm that wasn't idle.
I ran around and practiced more for the next 2 days. Taking it slow and going up to 45 mph and up to 4th gear, though most of the miles were still put on at the mall to perfect my mechanics. (have not had any heat problems since)
All of a sudden I had it in neutral and it died AGAIN! Tried to crank it and once again not enough juice. I called the original owner and he said he didn't know but assured me that the battery was only 3 months old. I hooked it up to my girlfriends car and let it charge for about 3 minutes. Cranked it and it worked. Let it run for about 5 minutes, even rev'd it a few times. Turned it off and tried to turn it back on. STILL NOT ENOUGH JUICE! I let it charge off my girlfriends battery again for about 20 minutes this time. Let the bike run for about 5 with a few revs and turned it off. This time it turned back on (probably because I let it charge for 20 this time instead of 3)
Can anyone please tell me if they know what's going on? Or what to check? Has anyone else had the same problems?
ANY ADVICE IS VERY MUCH APPRECIATED!
THANKS!
THANKS!
