Just a quickie, Is the cam chain tensioner automatic? or do you need to tension it yourself? My tapping noise is back with a vengence.
totally similar. I describe mine as a ticking. Dunno also has a similar problem. mine comes in at 2500rpm till 4700rpm.How do you know it's the cam chain ? I have a noise in my motor that suonds similar to what I think might be that. Took it to the dealership and they couldn't figure it out. It only rattles on the lower RPM wind down wether it is parked or moving. It sounds like marbles or a couple of nuts in a plastic jar rattling around. Sound similar to your noise ?
Cam tensioner runs off of oil pressure. Are you sure its not your clutch? When you pull the c lever in does it go away?Thanks for the liks my friend. Unfortunately I wil be a way off of fitting another can. Our third bundle of joy is comming in 5 weeks. We got 3 under 3...... So funds will be going to suport our local land fill site with organic matter and non biogradable nappies. I may just do what ausie jules did and drill the ends out.
No mate defo not the clutch, I had a mechanic try to tell me this. Until I reproduced the noise at 2700 rpm. I hear where your coming from though.Cam tensioner runs off of oil pressure. Are you sure its not your clutch? When you pull the c lever in does it go away?
Could you place a thread in the tech section as this could benifit others?Just found the cam chain (timing chain) tensioner. For my 2005 it's on the right side of the motor behind the frame and above the oil filler. Have to take it off the bike to test it. From what the book reads in a nutshell, if the rod inside dosen't move smoothly, it's defective. If anyone needs the details on exactly what to do P.M. me. I'll foward you the how-to. Just ordered the gasket and aluminum washer. The manual says to replace those two with new parts whenever you take it off.
I'll post another thread when the dealership comes up with my parts and I test the thing. Still waiting. . . .
Same as mate, My noise comes and go. I reckon I will go up to jonacs house with a spanner one night. He has got great cans (pipes) lol. I saw a full lazer system for £299.00. Seems a good deal. Do you know if anyone actually males a slip on end can?
Mate, I am gutted for us both, well for you mostly as you did all the work and had to cough up your hard earned dollars to replace a working part. Another frien of mine thinks it may be the noise of the fuel intectors. My noise is certainly louder when the tank is empty. I dont know if this is down to it just being able to resonate better?Finally got a chance to pull the tensioner off to test it. It's working fine. Not the source of the tapping. Now i'm back to scratching my head.
