- Joined
- Feb 7, 2009
- Messages
- 12,557
- Reaction score
- 1,210
- Points
- 113
- Location
- Cape Coral, Florida, USA
Hmm, I used peak global gold and never had a problems, pulled the puke tank and the radiator hose, of course I change mine every year before winter. I fill it up, let it idle till the fan kicks on, let it cool, and fill if needed. Make sure there are no leaks.
After I drain and re-fill (I do use the drain plug, no leaks, original washer), top off the tank, I go for a ride (I just want to make sure there's no air trapped in the system), get it to temp, then go home and let it cool down.
Once cool, I top off the tank and radiator if needed..
Just pulling the hose should be fine, especially since your doing yearly.. :thumbup:
