TheRustySpork
Hi Everyone
While riding to work the other day the clutch lever got stuck when i pulled it in to change gears, i managed to nurse it home.
I originally thought this was due to lack of cable lube, so today i went to lube it and discovered that the cable had actually sawed its way through the metallic part of the outer cable close to the lever! so i am in need to replace it. (The cable is OEM and 2 years old and regularly lubed)
so my question is, has anyone else had a similar experience and is it best to replace it with another OEM part or should i go for another manufacturer?
thanks
thanks
