thisisdylan
I changed the coolant recently, and it was working fine. My bike was getting hot after some easy rides, requiring the fan to turn on for about 3-4 minutes at the end of a ride (abnormal behavior even after the coolant change). I checked the rez and there was a crack in the plastic at the high level mark that I had not noticed before, and the level was below low.
I sourced a used part and will pick it up in a day or two. What are the required steps to replace this? I could not find a record online of someone performing this. I'm guessing the tank will need to come completely off, but that's all that comes to mind. Anything else special needed?
Thanks
Thanks
