chris_fz6
Can someone shed some light at why would my radiator fan not kick in please?
Bike is FZ6 2008
I have now tested and replaced everything on the radiator fan harness side and the fan still doesn’t kick in at 100C (212 Fahrenheit).
Tried new (used) cooling fan.
New relay.
New cooling fan fuse.
New temp sensor/switch.
Still doesn’t kick in at 100C
One weird thing I’ve noticed is that while measuring the voltage at the fan plug it’s only around 9 volts(first photo). Is this expected?
Second photo is measuring the voltage at the relay plug where power comes from battery(pin 87 and 30) on the diagram and I’m getting the exact same readings of around 9 volts. (Previously tested the fan by connecting it straight to the battery and it works every time).
Any idea if 9 volts is how much should go to the cooling fan? And if that’s not normal what could be the issue?
Thanks in advance.
Bike is FZ6 2008
New relay.
Thanks in advance.
