Kamloops
JoeDanger.com
- Joined
- May 14, 2008
- Messages
- 577
- Reaction score
- 18
- Points
- 0
- Location
- Kamloops BC Canada
I have a chance to buy a Kawasaki Klr650 for 800 dollars and it has only 11,000 miles on it.
The only problem is a rock hit the oil drain plug and put a hole in the crankcase. The owner used jbweld and it has held for 3000km without leaking.
Can no longer use the drain plug to drain the oil have to suck it out or tip the bike on its side.
I am thinking a welder could weld the case if the bike was drained and turned upside down. Maybe put in a new drainplug (helicoil?)
Any advice? Is 800.00 a good buy, other than this the bike is fine.
He says the damage was about the size of a Canadian Loonie and that it is right where the oil drain is, he says he cant use the drain plug to drain the oil anymore so I guess that got damaged and he must have JBwelded it.
He did say you would only have to replace the case on that side if one were to go that route, but I imaging that would be very $$$.
