AGSTS
Well, all the engine mounting bolts are torqued, CCT swapped, although the old one looked and worked just fine.
....and the result is?Well, all the engine mounting bolts are torqued, CCT swapped, although the old one looked and worked just fine.
Well the chain noise has not changed significantly and the vibrations seem to still be there, although I could’t test drive the bike - it was pouring rain. However, vibrations on idle still are there. Seems like running out of options.. no idea what else could cause those vibs. Now the only thing that has not been done is valve lash check.....and the result is?
