- Joined
- Feb 7, 2009
- Messages
- 12,538
- Reaction score
- 1,185
- Points
- 113
- Location
- Cape Coral, Florida, USA
This post is just an FYI.
The starter relay that failed is off my 2006 Yamaha F150HP (about 2300cc's) OUTBOARD ENGINE that failed last spring(would NOT spin/CRANK over, just "click"). It was diagnosed and replaced shortly thereafter. (no issues afterwards)
Just for S&G's, I cut it apart this afternoon to peek..
It is a larger relay (about $80.00 worth), with a fairly large coil to activate it. The coil worked fine, it always "clicked", but it did NOT allow 12 volts to make to the starter.
Here's why;
You can see how bad the contacts / connections are on the left side. It is very well constructed/sealed but normal wear and tear took its toll..
Here's why;
