JoeSTL
Well I got my Race Tech springs the other day, and I'm curious about a couple things during replacement. Last year I changed the fork seals and springs on my beginner gs500 and it was a fairly easy process, so I know this shouldn't be too bad either.
First question, if I'm only planning on replacing the springs and the oil, do I need to take apart the entire fork? The dust covers are in great condition and the seals should be as well, since I've never had any kind of leakage.
Second question has to do with the spacer length. Should I use the stock spacer or should I cut the one sent with my new springs? What length spacer do you all recommend for a guy weighing 260 w/o gear?
Thanks for your help!
