Just noticed today that I have a screw stuck in my front tire, though there is no drop in pressure. I am afraid if I pull it out, the tire will go flat.
Anyways, I have to change the front tire now. I have the stock Dunlop Sportmax D220F ST 120/70 ZR17. I a wondering if there will be a proble if I put on a 120/60 ZR17 instead of the same brand/tread pattern?
Also wondering if these tires can be repaired once the screw is out.
thx
I'm more liberal, when it comes to mix and match of tires. The difference between a 120/70 and a 120/60 is the height of the side wall with respect to the tire's width. The /60 will result in a slightly shorter outer wheel diameter, so the tire
may steer quicker. It could affect the tire profile, as well, as the shorter sidewall will result in the tread pattern being slightly more 'peaked'.
But this is all theoretical..... as we don't know how close to the ideal the tire that is currently on your bike is, or how close the replacement is to it's ideal.
60% of 120 = 72
70% of 120 = 84
The outer wheel diameter would be reduced 12 mm providing both are exactly on their spec'd dimensions.
But..... what if the tires are simply within a 10% tolerance of the ideal? You could very easily have tires from different mfgs that are physically exactly the same size, but identified as different on the side wall. Note that in the example above, the 10% difference happens to be 12 mm, as well. The opposite is of course possible. A max differential, one being 10% low, and the other being 10% high, would result in significant difference.
Me personally.... I don't like plugs in front tires. A blow out on the front is a much bigger deal than losing the rear. Neither is fun; one is much more likely to be catastrophic.
Knowing a plugged tire is (in my opinion) an unacceptable risk, I rate a 'mix' of tire brands front to rear far more acceptable than a plugged 'like' brand.
Swap the tire, and take it easy until you know how it handles.
