s6xtyn9ne1974
Im new here so I may be posting in the wrong area. Sorry if I am. I have bought Led tail light. It has the turn signal built in to it. there was no cutting of the wires. easy to install. After I got it all back together. I turned the key on and noticed the head light was not on. I tried starting but it just keeps turning over. this is a 05 FZ6. You can hear the fuel pump enguage when you turn key on. there is an error that reads er_1. Im assuming my problem is the wiring since I just change the tail light only. Before changing the tail light everything worked and ran fine. I checked fuses next to the seat for the head lights and checked fuses on the battery. all of them good. I even plugged old turn signals and tail light back in. still having same problem. no head light and turns over but will not start cause of the er_1 error. My question is has anyone had this problem before or heard of anyone that has had this problem? If so how can I fix it? changing tail light was simple task with everything fitting just perfect. not sure how this happened. It just dont make any since. If someone could help then that would be awesome. Thank you...
