Pat Unit
Bought a 2005 fz6 with only 5000 miles on it, that's been sitting almost two years. I tuned it up a little bit before trying to run it, clean gas, sea foam, new spark plugs, new battery, clean filter, etc. The starter is cranking like a champ but I couldn't get the engine to turn over. I tried using starting fluid and got it to turn over! But only for a couple seconds, then it died again. So the engine is definitely not getting gas, but where do I start in my search to find out why? Do I try the fuel pump first or go straight to the injectors? I'll check the fuel lines just in case, but after that where do I look?
