hot4teach
Today I started to pull the airbox, battery, etc. I thought there must be an easier way that can be almost as clean in the end. I pulled the switch assembly appart and there was the green wire. I soaped up a wire and fed it through the factory rubber loom to the point where it is split open near the tripple tree. I routed it along the factory loom to the bulb and made the standard connection there. Then I soldered the wire to the green wire on the back of the switch. Reassembled and done. I have a pic of the finish, but didn't take any during the process as I was at work.
Pic shows the black wire exiting the factory loom.
