Dennis in NH
Only thing I did was put a switch on the wire that feeds the headlight mod. I actually tested it yesterday and the light switched off/on. This switch is an illuminated switch (3 wires: to battery, to load, to ground; I only connected the to-battery and to-load and capped off the to-ground wire so it is not illuminated).
This morning bike would not start. You press the starter and bike makes the starting noises but never catches and gets the engine going. The battery should be strong as I put it on the trickle charger until it turned green -- just in case it was just a low battery.
What could this be? I'm wondering if I blew a fuse. But if I did, would I hear anything? -- because I hear the starter cranking. I'm going to pull the tank now.
Thanks,
Dennis
Thanks,
Dennis
