QwickFliCk
Manly Man Member
Good JOB!!!
You might just uncap the 4 tubes and let some air be sucked up (a couple minutes). The point being once you cap them, the oil could deteriorate the tubing.
thanks man! i thought if air was introduced into the system was bad? i dont want the tubing to deteriorate...i was thinking to clamp off a part of the affected hose and spray a little engine degreaser or something to remove the oil in the tube and squeeze it out or let it air dry
QwickFliCk, re the gunk inside the throttle bodies, you can clean them out with carb cleaner, it should help it running too. Spray a little at a time with the bike running (unless initially you can a rag behind there-engine off to soak up the goo). I'd put a large fan in front of the bike when running it on the centerstand to help keep things cool...
i doubt i can get a rag thru there...will the carb cleaner mess up any sensors...i was thinking to get the sea foam spray or mass air flow sensor cleaner just in case
