ant_mb
Super *********
Has anyone done a HID light conversion on the FZ6? I want to get one and was wondering if anyone had any feedback on it.
Sorry, my reply sounded kind of rude, it wasn't meant that way!It just seems that most HID kits are sold with matching lights, and I plan on converting to a single style bulb.
Someone on here had a very good thought. buy the dual headlight kit and then buy a replacement HID bulb of the other size and just plug that one in instead to the other side.
Be aware that it's not straight-forward with the H4 on the high beam side. There are at least 3 types of H4 kits:
- H4Lo - the Xenon bulb does just the low beam and there is a halogen filament for the high beam.
- H4Hi - the Xenon bulb does just the high beam and there is a halogen filament for the low beam.
- H4-3 - there is a single xenon filament and there is also a solenoid triggered by the high beam switch to move the filament between the hi and low positions. There is an added complexity with an extra relay that comes with this version.
The 1st option wouldn't work, the 2nd option is probably ok. However, I think that a combination of the BK Headlight mod in conjunction with the H4-3 kit and getting 2 types of Xenon bulbs (H4 + H7) would probably be the way to go.
This should be interisting!![]()
That looks like the H4-3 kit then! I guess you're putting it on the RH side?
Also, can someone explain what, exactly, HID is to a novice?
Thanks![]()
