Lubing rear axle and bearing?
2wheelieadv
Nj
When I took the rear wheel off to replace the tire, I took the spacers off and on the left side (sprocket side) I noticed an open bearing. Nothing was greased and it made me wonder if I need to grease up these parts when putting all back together. Maybe not so much for the spacers and axle, but maybe at least the bearing itself?
I just checked the service manual, and they say to grease it all with white lithium soap.
Bearings, axle, oil seals, they grease it all!
i always grease them when I take the wheel off
bearings will probably explode if left ungreased, and the axle might end up corroded in place
Where is this needle bearing? I replace both tires on my FZ6 last fall and only saw the sealed bearings on each end of the hub. Is the needle bearing internal?
Anyone??? I looked at a diagram in the service manual but cannot figure out where the needle bearing is located. I did not take off the sprocket or damper so is it under there?
Yes, you have to pull the hub and sprocket away from the wheel. Then you see this:
From: http://www.600riders.com/forum/garage-mechanical-help/52142-needle-bearing-removel.html#post574172
