Oil filters that will fit
colobb
Steamboat Springs, CO
So, if I am understanding this correctly, the following are no-no's, right?
AC Delco PF2135
AMSOil SMF103
Carquest 85358
FRAM PH6017A
Honda 15410-MCJ-000
K&N KN-204, about $13. Metric nut on end for easy removal.
NAPA Gold 1358
Purolator ML16817. Imported, not made by Purolator.
STP SMO 17
WIX 51358
BranNwebster
The UNO Master
Webster Texas
Fram Extra Guard
Years ago Fram was a quality filter manufacturer. Now their standard filter (the radioactive-orange cans) is one of the worst out there. It features cardboard end caps for the filter element that are glued in place. The rubber anti-drainback valve seals against the cardboard and frequently leaks, causing dirty oil to drain back into the pan. The bypass valves are plastic and are sometimes not molded correctly, which allows them to leak all the time. The stamped-metal threaded end is weakly constructed and it has smaller and fewer oil inlet holes, which may restrict flow. I had one of these filters fail in my previous car. The filter element collapsed and bits of filter and glue were circulating through my system. The oil passage to the head became blocked and the head got so hot from oil starvation that it actually melted the vacuum lines connected to it as well as the wires near it.
interactive3
FZ6 Rider
Premium Member
Saxonville, MA
These Oil Filters
have 20 x 1.5mm threads,
14 psi by-pass valve,
anti-drain back valve,
2.3\" O.D. gasket
2.5\" to 3.5\" long.
If you have the room, I recommend the longer filters.
Recommended filters.
All have superior filtering.
About 2.5 inches long.
Purolator Pure One PL14612, about $6.
Mobil M1-108, about $12.
Made by Champion.
Bosch 3300, about $6.
Made by Champion.
About 3.25 inches long.
Purolator Pure One PL14610, about $6.
Mobil 1 M1-110, about $10.
Made by Champion.
Bosch 3323, about $6.
Made By Champion.
WalMart SuperTech ST7317,
about $2. Made by Champion.
Buy these filters Automobile Filters,
about 2.5 inches long.
AC Delco PF1237
Baldwin B1400
Firestone TF2876
Hastings LF113
NAPA Gold 1365
Purolator L14612
STP S-02876
WalMart SuperTech ST6607
WIX 51365
Automobile Filters,
about 3.25 inches long.
AC Delco PF-2057
Auto Pro 2356
Autopride CF240AP
Baldwin B1402
Carquest 85356
Carquest Red B4620
Casite CF240
Castrol 7317
Champion Labs Ph2867
Defense Filters Dl7317
Deutsch D-370
Federated Filters LF240F
Automobile Filters,
Fram Double Guard DG7317
Fram PH7317
Fram Tough Guard TG7317
Fram Xtra Guard XG7317
Group 7 V4610
Group 7 V4620
Hastings LF240
Mighty M4612
Motorcraft Long Life FL-821
Napa FIL1356
Napa Gold 1356
Parts Plus PH2867
Pennzoil PZ-109
Penske 7317
Powerflo SL14610
Powerflo SL14620
Pro Gauge PGO-4620
Pro Tec 164
Promotive PH4610
Pronto PO3593A
Purolator L14610
Service Champ OF-4622
Shell SH48
Shell SH529
Stp S-02867.
Valvoline VO50
Warner PH2867
Wix 51356
I highly highly recomend the purolator pure one filter PL14610 for less than 6 dollars it is one of the finest available.
Which filters have you used? Is there room for the 3.25" long filters or does the FZ6 need the shorter 2.5" long filter? Thanks.
wrightme43
This one every time.
GConn
Squid hater
Nicosia / Cyprus
As indicated before I think that the 07+ model uses different filters than the 2004-06 model. Anyone knows the equivalents for 2004-06 model?
wrightme43
Are you sure? The engine block has not changed at all.
The same filter fits the R6S as well if I remember correctly.
GConn
Squid hater
Nicosia / Cyprus
I am not sure at all. But I am sure that I read this somewhere before + someone else mentioned it in this thread too. That's all I know about the issue
EDIT: Just for reference, the K&N filter I used on my 06 last time is model 303. What model of K&N do you use on 07+?
I am now looking into new filters after reading some stuff on the net. A friend imports Champion stuff, so I need to find the model that fits my bike. If I find it out, I'll post it here.
jpainter187
Texas
Hey, I was thinking about ordering some of the Purolator Pure One PL14610 oil filters from Amazon.com but how can I make sure that they will fit? I don't see anything that would get in it's way... This will be my first oil change so I want to be aware of any possible issues that I could run into before attempting it.
jpainter187
Texas
...Oh well...
I just ordered 6 (3 two packs) of the Purolator Pure One PL14610 filters from Amazon w/ free shipping at less than $5 a piece. Should last me a while:thumbup:
Hope they work!!!
cp04
Dunder Mifflin Employee
Lexington, Ky
The majority of oil filters on the original list posted are the part numbers for automotive filters that will also fit on alot of bikes. The K&N 204 being one of them. The K&N 303 is listed on the K&N website as being the bike specific filter for a FZ6.
mellofelow
Los Angeles
...Oh well...
Hope they work!!!
That's what I use. Let us know the color of the filters. Purolator switched to yellow recently. I got mine from Pep Boys... still blue on the shelf.
wrightme43
the 303 and the 204 both have this thread size and pitch.
They will both fit.
Red Scorpion
Ga
So you are going to need to add more oil to the engine to make up for the added volume of the longer filter?
RS
