R6 Adjustable Fork Swap Kit! (Forks, Brakes & Spacers)
visions
THAT guy
Sacramento, CA
Price drop! see last posts for current price
This is for the R6 fork swap, add adjustable forks and better brakes to your FZ. Comes with forks (straight, no leaks- came from a later model R6s) matching brakes (lines/lever not included) and the custom machined spacer kit & shims to make it all work (allows stock 04-06 fz fender)
$375 shipped, US only
QwickFliCk
Manly Man Member
NY
I'm interested so dibs. But I gotta ask why r u selling it and will the brake calipers fit the oem banjo bolts from an 05 fz6 or do I have to get new lines? Also does it come w the axle?
visions
THAT guy
Sacramento, CA
I'm selling because I put on inverted forks.. The bolts are the same size as stock but I really recommend braided lines :) and sure you can have the axle too (its stock fz6)
Thanks :D
QwickFliCk
Manly Man Member
NY
Thanks :D
no way thats a stock fz6 axle :confused: i thought all the fz6 front wheel axles take a 19mm hex socket. maybe im not lookin at that pic right:confused:
also i have goodridge ss lines on my bike now i was just making sure they will fit
Axle from the R6 is needed for swap as the FZ6 axle is basically a long bolt which is threaded on the outside and the R6 axle is tube which is threaded on the inside for a short bolt to be inserted on one side.
visions
THAT guy
Sacramento, CA
yes the fz6 is pretty much the same across the models :)
unfortunately im not willing to ship international
