Fz6Junkie
So I did a search here on the subject and although some issues are similar, I just wanted to throw my particulars in there to see if the issue can be diagnosed better or just left alone. Bought my 08 last November with 7260 miles on it and just hit 9000 over the weekend. The only engine/exhaust mod I did was a Delkevic carbon fiber exhaust to replace the quiet/buzzy stock exhaust. I rode the bike throughout the winter and spring here in Knoxville, TN so it was cold/cool most days and no smell of gas. It wasn't until a couple months ago that I started to smell raw gas after the bike came up to temp. I smell it while riding like when I come to a stop at a light or just idling with no wind and proceed to stink up the garage for a couple hours after I get home while the bike is cooling down.
I originally thought it was coming from the fuel cap but right after getting off the bike the other day, I sniffed around the right the right side of the bike just below the gas tank and the smell was strong. I saw someone's idea to disconnect the battery after an exhaust install as the fuel mapping may have changed with the exhaust and needs a reset. I've installed a couple of mods (HealTech Pro Brake Light Pro and Gear Indicator and Denali Soundbomb) since the exhaust install and the battery had to be disconnected for those so unintentionally, I've had the battery disconnected for at least 10 minutes. Are there any hoses or lines connected to the underside of the tank that expel fumes as the temps rise?
Here's a checklist of what you may ask:
Is it popping or back firing on deceleration: No
Does it stumble at low RPM's? No
Are the plugs looking funny or wet? Have not checked the plugs.
Does it idle high or rough? No
Is it running warmer or cooler than normal? On a looong ride yesterday in 90 degree heat, the engine temp was around 185 degrees.
Is the exhaust visible, and what color? Exhaust is clear.
