hk_fz6_05
Hey guys
so this is a reasonably minor issue, but it has me stumped for the moment and any help would be appreciated.
I'm in the process of removing front wheel and can't get my motovation fork sliders off.
One slider bolts on to the through axle rod and slides through the axle and the other slider bolts on to the other side. My problem is that only the slider on the side where it slides in comes loose while the one on the other side (where the rod can't slide out) sits stuck.
So, how do I get the bolt that's not loose loose? Or will the axle come out even with the rod in place (ie. does it even matter?)
thanks.
thanks.
