VS2 Headlight Kit
Signal 50
CT
I bought this last year, and with the amount of highway riding I do, I decided it's not for me. I returned my bike to stock.
I put this kit on in September of 2011. I rode the month of September with it. Parked the bike most of October, and then in November we got the infamous "winter snow storm" of 2011 and it sat unridden all winter.
-The kit does not come with turn signals.
-I had to modify one of the side covers a little bit with a dremel. This sounds worse than it really is. You can only slightly see it when you are sitting on the bike. I took pictures of this and inluded a description below.
- You will need to use some rubber spacers from the stock fairing on the speedo bracket. Just yank them off when you disassemble things.
- You will need to order the rubber bushings, or longer allen bolts to go through the mini fairing. They were not included in my kit. I used smaller bushings and smaller bolts. If you'd like to use the stock bushings you will need longer bolts. I can clarify this with some better pictures if you'd like. I don't want it to scare anyone off as it is a very easy fix.
- Comes with the headlight relay mod from Motogiro. Brand new with directions.
- Comes with FZ1N Headlight cover.
- I am thinking 200$ shipped tentatively.
Here is everything I have. The kit includes the headlight housing, mini fairing, headlight bracket, speedo mounting bracket, and FZ1N speedo housing. The first headlight I recieved from Vishnu, I snapped one of the mounting bracket. I will include this light for spare parts, or scrap it if you don't want it. Totally up to the buyer.
The painters tape is just too hold some bolts and spacers together in their proper location. Just so I don't lose anything.
In this picture, you can see I had to modify one of the plastic side covers a little bit. This piece rubbed my right fork so I took a little material off with a dremel.
Back of the headlight
Headlight bracket with all hardware attached.
From the front
Signal 50
CT
I am interested, but would like to see some more pictures from the side and back on the bike if you could. Thanks in advance!
Sorry, I have my fairing back on. I pointed out what I was referring too in the pictures above. Here are a few more.
What you see from the top
What it looks like directly from the right side.
Comparing both sides.
