raj_27
Thanks for all the information in the forum for installing handgrips, its great help. With lot of searching i have figured out what i need to do to wire a relay between battery and grips so that they are switched with the ignition key. Installed the grips and grip controller, now i am stuck and confused what should i do.
There are plastic connectors at the end of wires from each hairgrips which connect to controller. Another connector at controller connects a long wire which connects battery.
when i try to route wiring same way as all other handle bar mounted cables, the connectors sit out side. They are not long enough to end near battery. They are not even long enough to be tucked in the fairing.
My questions are
can i leave them outside where water and dust can get into or should i cut the connectors and solder and heat shrink them? Or am i missing something?
My questions are
